Check engine light is on
MITZI GIBBS-HARTMAN
  • 2006 HYUNDAI SONATA
  • 3.3L
  • 6 CYL
  • FWD
  • 220,000 MILES
Upon having a code reader I checked the code it came up a po441. Help!
Thursday, August 3rd, 2017 AT 8:24 AM
STEVE W.
  • 15,320 POSTS
P0441 Evaporative Emission Control System Incorrect Purge Flow. Fastest way to test this is with a scan tool and a smoke machine. It could be many things. From a rusty filler neck to a bad purge control valve and about 10 others. Some you can visually inspect but most you need the abilities of a scan tool to open/close the various valves as you test them.
Thursday, August 3rd, 2017 AT 3:01 PM
