Alright, so I installed the new gaskets. The old ones were leaking bad, on the old gaskets I can see where dirt was partially blocking the vacuum leaks and I mean really only a few of the gaskets were not leaking. There was tons of dirt around the gasket surfaces. So I got the gasket surfaces and all under the manifold all cleaned up, cleaned up the intake ports too along with the ports and everything on the manifold itself. First start up after replacing the gaskets it was still idling rough but it got better and today it has went to basically an intermittent rough idle. I had a couple times today where it took a few tries to start. Also, I still have the engine kickback on hot starts. Looking at what I know, I I know it is getting air. So it has got to be either spark or fuel right? The readings from the O2’s at idle get up to 0.800 volts so as far as I know this means it is getting plenty of fuel? So if this is true, and if the rough idle and hard starts have the same cause, then it would be spark? Oh also, I forgot to mention earlier in the post, the long term fuel trims at idle are now as follows, bank 1, 4.7% bank 2, 0.8%.
Sunday, April 15th, 2018 AT 9:31 PM
