Check engine light blinking skipping and my radiator tank cracked and coolant all over engine distributor.
MICHELLE1975
  • 1996 TOYOTA TACOMA
  • 2.7L
  • 4 CYL
  • 4WD
  • MANUAL
  • 225,000 MILES
Will the coolant getting on my distributor and possibly getting inside it will that cause it to misfire? Also its like 41 degrees outside and I noticed what seemed to be stem or maybe smoke white would that be just from the cold weather
Sunday, January 25th, 2015 AT 9:02 PM
JOHNNYT73
  • 924 POSTS
Yes, you should never get any kind of liquid in the distributor. If its white smoke that smells sweet like coolant then you are getting coolant into the combustion chamber, which is a symptom of a head issue. If its just steam from the cold then its obviously no issue.
Monday, January 26th, 2015 AT 5:05 AM
