Charging system
1999 FORD F-250
183,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
WILLIAMOD91
A few days ago my battery light started flickering and checked the alternator and I passed and found the voltage regulator was bad. So I changed it and it has been running fine for three days now. However, now I watched the battery gauge drop slowly and now my trucks not running again. It has a new battery as well. What could be my problem?
Sep 20, 2018 at 7:30 AM
Good evening.
What brand alternator did you use? Was it new or rebuilt?
If you have a voltmeter, check the voltage at the battery. With the engine running it should be 14 to 14.5 volts.
You may have a bad new alternator.
Sep 20, 2018 at 8:39 AM
