Electrical problem
1984 Ford F250 V8 Four Wheel Drive Automatic
I have replaced the alternator, battery, and voltage regulator on the truck. Yet when it is running it only pushes 12.5 volts. Is there anything else it could be if so please let me know.One mechanic said it could be the ignition control switch in the steering column, is this possible.Thank you for your time. Robert
Mar 9, 2009 at 5:40 AM
