Engine misfire? Can you help me fix it?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
O man, sorry we did not mention that earlier, you do a great job with the videos.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Saturday, January 16th, 2021 AT 9:26 AM (Merged)
LSQUIRES
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 93,000 MILES
I noticed car idling rough and jerking on acceleration. Mechanic said water in gas. Tried bottle of heet; didn't work, check engine light came on; code read misfire #3; mechanic replaced plugs, wires, upper intake gasket; used some fuel injector cleaner; cleaned throttle plate. A little better but stlll when slow down and then accelerate back up it chugs; runs smooth otherwise except same day we got it out of shop check engine light came back on. Took it back to mechanic--he says fuel injectors need cleaning which will cost another $300. I hate to keep throwing money at it trying to find what's wrong--but I'll need to get it through emissions in a few months- Help please!
Saturday, January 16th, 2021 AT 9:27 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Could be an injector that is going bad, working intermittently. Sounds like everything else has been replaced, except the ignition coil and injector, both of which I have seen cause misfires on these cars. Cleaning the injectors seldom lasts.
JABRUNN
  • 12 POSTS
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 166,000 MILES
I have a 2002 Ford Taurus with the 3.0L OHV engine. I have been experiencing a missfire ever since purchasing the car. I have replaced so many components I'm down to a valvetrain issue. I just did a running compression on two of my cylinders and both were not even reaching 30 psi. When I revved the engine the compression dropped way down to barely being registered on the gauge. Is this evidence of weak valve springs or no? Also, the CEL is not being illuminated but the Mode6 data from my PCM indicates a small misfire on all cylinders (the last time I checked it).
Saturday, January 16th, 2021 AT 9:28 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Dry and then wet compression test should be done 1st, compare reading
running compression test not so sure
JABRUNN
  • 12 POSTS
I did a dry compression test several months ago and everything checked out. All cylinders were within 15 psi of each other. The running of the vehicle hasn't changed since then I just decided to finally take a stab at checking the running compression. I can do a wet compression but it would be this weekend before I could do it.
BLACKOP555
  • 10,371 POSTS
Don't rely on a running compression test. OK with that out of way when do you feel it miss firingthe most. High load. Light load. Idle? Maybe all the time
Saturday, January 16th, 2021 AT 9:29 AM (Merged)
