Engine stalls while driving?
GROVERGODWIN1
Thanks Could you tell me where the IHV would be located. Looked for 1/2 hour on internet and it wont tell me anything.
Monday, September 7th, 2020 AT 2:25 PM (Merged)
JAMES W.
  • 2,394 POSTS
I must have had cramps in my fingers when I entered my last response. Let me try again. Can you give me the actual codes that were retireved from your last scan? I doubt, not that it isn't, that it's a problem with the ECM.
PESSETTI
  • 2005 KIA OPTIMA
  • 4 CYL
  • FWD
  • 70,000 MILES
When driving engine tends to loose power cut out like it is starved for gas then it will pick up and take off.
  • 109,885 POSTS
It could be caused by a couple thing. Have you ever had the fuel pump pressure tested? Also, have you had the catylatic converter checked to make sure it isn't clogging. Has the check engine light come on?
