HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Acura
Legend
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
No crank not start issue?
PREV
1
2
NEXT
AL514
MECHANIC
Okay, glad it was something easy. That starter would take all day to do. Glad to help.
Tuesday, October 18th, 2022 AT 3:15 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
My Car Turns Over But Doesnt Want To Start. What Do...
I Go To Start My Car And It Just Turns Over. What Do You Suspect Is The Problem?
Asked by
swendog76
1 ANSWER
1992
ACURA LEGEND
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1992 Acura Legend Car Won't Crank In Cold Weather
This Is My Second Winter With This Car. Last Winter I Took It To The Mechanic Shop And They Had No Idea What To Do To Fix The Problem. I Had...
Asked by
Marlene York
1 ANSWER
1992
ACURA LEGEND
1993 Acura Legend Won't Crank
Lights, Strong, Batt. Voltage High, Tapped On The Starter While Ign. In Start Position
Asked by
dmccorri
1 ANSWER
1993
ACURA LEGEND
Car Will Not Start
Six Cylinder Two Wheel Drive Automatic 190,000 Miles I Changed The Timing Belt, Water Pump, And Oil Pump In My Car, Got The Car To...
Asked by
nostalgiajm
1992
ACURA LEGEND
Motor Vibration
Acura Legend, 1992;motor Vibration. Usually Starts At 1200 Rpm. Mechanic Checked Motor Mounts[ok]. Put On Diagnostic And Could Not Find...
Asked by
baccarat3
1992
ACURA LEGEND
VIEW MORE
SPONSORED LINKS
Battery Replacement Ford
Battery Replacement Guide
Online car repair manuals
