Well, to be honest, I would check the starter itself. It is fairly likely that the solenoid switch on the starter is going bad. The easiest way to check it is to simply connect the posts on it with a screwdriver when the car will not start. If it cranks, then you have confirmed your problem is that switch.
SPONSORED LINKS
Thursday, March 1st, 2018 AT 6:37 PM
