Car wont start after I brought a new crank sensor, ignition coil, spark plugs and wires, vavle cover gasket
KAY900
  • 1999 DODGE STRATUS
  • 2.4L
  • 4 CYL
  • FWD
  • 89,000 MILES
The car cranks but no start, I goto check the fuses and the pcm, asd fuse keeps blowing out. I cant find a wiring diagram nowhere online and I cant bring it nowhere to get the correct diagnostics nor hook up any code reader or such.
Thursday, August 14th, 2014 AT 6:07 AM
HMAC300
  • 48,601 POSTS
Try resetting antitheft first if no manual look online. Asd relay supplies power to ignition box and pcm as well as O2 sensor before converter. Also switch asd with a like relay see if that makes a difference
Thursday, August 14th, 2014 AT 6:55 AM
