Engine will not start
270,000 MILES • 5.3L • 2WD • AUTOMATIC
KB LALA
Truck was running just fine but now won't crank but lights until I try to crank it and it's like the car doesn't work. what could it be?
Feb 26, 2022 at 8:01 AM
  • 110,248 POSTS
When you turn the key, does the starter engage and the engine fails to start, or does nothing happen?
If the starter engages, it could be a few different things. For example, a faulty crankshaft position sensor or low/no fuel pressure. If the starter doesn't engage, then we could have a weak battery or an issue with the starter circuit.
Let me know exactly what happens. Also, if you haven't already, I need to confirm the battery is good. Here is a link that explains how to load test a battery at home without tools. Do this and let me know the results.
I will watch for your reply.
Feb 26, 2022 at 2:23 PM
