Car will not start
185,551 MILES • 2WD • AUTOMATIC
TERRIJOIGMOE
Tried starting it in park it kind of jerked a little bit then wouldn't start, put it in neutral then park again still wouldn't start. then went to front of car pushed its little it back on the did park to neutral then park it started. next day it starts drives about four miles then shut off won't start then does.
Mar 27, 2022 at 2:15 AM
I may be wrong with this, but I suspect going from park to neutral and pushing it was not related. It sounds like you have a starter solenoid issue only if when you are trying to start the engine it does not crank. Meaning when it is not starting does the engine spin over and not fire or does it not respond at all?
Here is a guide that talks about this:
As for the shutting off, that may be a different issue unless the engine cranks over but does not start. If that is the case, then we need to run through this guide and start checking fuel and spark:
https://www.2carpros.com/articles/engine-stalls
This could be a crank sensor issue or even a failing fuel pump.
So, let's start with checking the fuel pressure when this happens.
Let me know about this info and we can go from there. Thanks
Mar 28, 2022 at 2:08 AM
