i put an exhaust gasket on the car and hit camshaft sensor and the wire came out of the sensor i try put the wire back in, but did not know where or the right way to put back the sensor had two black wires and one brown .Then i found out how the wire want and they keep falling out so went and found the camshaft connecter put it back together and the car would not start. So i check the car and found that the fuel pump was not working
so i replaced the fuel pump and the car still would not start. i checked the fuses they look to be good so what do i do now? i also tried checking camshaft sensor with multimeter i do not know if i checked it right. so i also need to know the right way of checking the camshaft sensor and do i need to check the crankshaft sensor?
Dec 10, 2016 at 12:50 AM
