Car won`t go into gear
19,000 MILES • 1.9L • 4WD • MANUAL
TINZ
The gear has been getting harder to go into gear while driving . I have stopped the car, tried to put it into gear and it won`t go into gear at all. It`s fine when the engine is not running but when it is it won`t go into gear.
Jan 22, 2014 at 12:15 AM
  • 110,251 POSTS
There is a problem with the clutch disengaging the transmission. Your vehicle has a hydraulic clutch. Have you checked the fluid to make sure it isn't low?
Jan 22, 2014 at 12:46 AM
TINZ
Yes i have checked the clutch fluid and it is low
Jan 22, 2014 at 1:41 AM
  • 110,251 POSTS
Refill the fluid and see if that helps.
Jan 22, 2014 at 9:34 PM
