After having the transmission rebuilt and installed engine will not crank
BRANDON SUMMERS
  • 1996 FORD MUSTANG
  • 4.6L
  • V8
  • 190,000 MILES
Okay, so I took my 4r70w transmission and had it rebuilt. After finally getting it back In place, I get everything wired up. Go to start the car, and for some reason my ABS light, my low oil light and the theft light all come on when I turn the key all the way over. I don't understand. Please help.
Saturday, June 6th, 2020 AT 5:13 PM
STEVE W.
  • 13,478 POSTS
The first thing I would do is verify that you don't have a pinched wire or connector in the wrong place. Easy enough to get one caught between the transmission and the engine. If you find no wiring problems then I would start with testing the battery, if it went dead it is possible for the ECU to get "confused" and need to be reset to get things working again.
Sunday, June 7th, 2020 AT 2:57 PM
