Recently it gave a P0401 code so I decided to clean and replace a few pieces because the car is older and the job was simple (so I thought). I replaced the EGR valve, the solenoid, cleaned the throttle body (removed fully), check all the hoses and the code was gone and the gas smell was gone. I then replaced the air filter as well.
Since I cleaned and replaced everything my car now has issues with it's idle, always when cold when sitting all night and then only when I use the A/C during the day. Once it is warmed up and I am not using the A/C it is fine for the most part.
Everything was fine prior with the idle so I figured the car may be relearning.
But it has continued to have the problem the last several days. Every time the car is cold, I have to press the gas a little to let more air in.
Any help on the cause of the startup issue?
May 2, 2019 at 6:57 AM
