Car won't start
115,599 MILES • 4 CYL • AUTOMATIC
ANDCHIE
The security light has been coming on and someone's out stays just fine and it has done it 3 times now in the last week. The power comes on but car doesn't turn over, nothing. The change oil light and check engine light have both been on since the car's had 100,000 miles on it. The oil has been changed once since then. It was around 8-8 months ago.
Dec 20, 2015 at 4:21 PM
HMAC300
  • 48,601 POSTS
try resetting security system if it still doesn't start have a pro scan for codes for a security problem
Dec 20, 2015 at 11:19 PM
ANDCHIE
How do I reset the security system?
Dec 20, 2015 at 11:21 PM
HMAC300
  • 48,601 POSTS
I attached the instructions on an image do not try to start like instructions say just start by turning key on until security light goes out. do that 3 times. if light does not go out then you need to scan and see what is wrong with system. also if you have another key try that as well.
Dec 20, 2015 at 11:46 PM
ANDCHIE
The security light goes out everytime
Dec 21, 2015 at 12:04 AM
HMAC300
  • 48,601 POSTS
ok hen try to start it if it wont start still then have a pro scan to see if it's security etc. also check battery for condition including load test.
Dec 21, 2015 at 2:19 AM
