Car will not turnover
181,337 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
CALVIN FOBBS
After leaving the lights on the battery drained. Charged battery now it will not start.
Nov 6, 2017 at 1:14 AM
  • 110,248 POSTS
Does anything happen when you turn the key?
Nov 6, 2017 at 9:07 AM
CALVIN FOBBS
No..dash comes on hear everything working, but when i turn key on nothing happens..no click no nothing
Nov 6, 2017 at 11:28 AM
  • 55,594 POSTS
It sounds like one of two things has happened. Either the security system is engaged which you will be able to tell by a flashing red light on the dash when you are trying to start it. Or you have a starter motor that has gone out.
Here is a guide the will show you how to test the trigger wire with a test light:
If the starter is found to be bad, here is guide that will give you an idea of what you are in for when changing the starter out:
You will need to raise the car safely.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Nov 9, 2017 at 4:03 AM
