1985 Jaguar XJ6 Turns over, catches, and dies
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
DCEBULA
I have changed the spark plugs, fuel filter in my 1985 XJ-6. The car will turn over, catch and run for a second or two, and then die. I am out of ideas-I am not even a novice mechanic. Any suggestions? Thanks a lot.
May 4, 2009 at 9:02 AM
BENTLEY EVERSLEY
  • 31 POSTS
To whom it may concern, check your cold start injector, It may not be fireing. Also try spraying starter fluid directly into the throttloe body, make sure you reatached the hose before starting. And last check the mass air flow sensor, it controls the fuel pump and the injectors. Good luck and let me know the out come.
Sep 11, 2009 at 11:42 AM
ISJEH061654
  • 24 POSTS
I would check the ignition switch when it dies do you still have power or is it loss and then comes back
Oct 2, 2009 at 12:23 AM
