Engine crank no start issue
150,000 MILES • 4.2L • V6 • 4WD • AUTOMATIC
WRB50
It cranks over fine, but will not start.
May 7, 2022 at 12:51 AM
SQM
  • 6,383 POSTS
Generally speaking, an engine will need spark, fuel and compression to start.
You will need to check to see if you have spark to the plugs.
You could have no sparks due to faulty ignition coil or module.
Also, can you tell if the fuel pump comes on when the key is in the on position?
An inoperative fuel pump can be due to a bad relay, wiring issue or a defective fuel pump.
Let me know a few more details of what you have been experiencing or if you have tried any specific steps.
Here is a helpful guide that covers the typical issues with crank/no start issues:
https://www.2carpros.com/articles/car-not-running-advanced
Let me know what you find or if you have any questions.
May 7, 2022 at 8:26 AM
