I just changed my clutch in my car. I started it and it ran. When I take it down the road I can hit 3,500 rpm's then shift to second hit 3,500 rpm's again then shift to third then it buck and back fires then when I stop it wants to stall. If I hit the gas a few times it starts to Idle again until I start shifting again. I noticed my negative battery terminal wire is frayed and when you touch it a rusty dust comes off and some of the wire is falling apart. Could this be my problem?
May 21, 2018 at 12:00 PM
