Battery issue
180,000 MILES • 3.8L • 4 CYL
BIANCA ATTYBERRY
I am having an issue with my car. I thought maybe the battery drained. When I tried to start it there was a clicking noise. then when I got a jump it tried to start but would not turn over to catch.
Sep 25, 2017 at 6:25 AM
STEVE W.
  • 15,418 POSTS
Sounds like a battery cable failure from corrosion. Very common for that because of the GM cable designs. Start with cleaning the connections on the cables at both ends and check to be sure they are still solidly attached by tugging on them. Next would be a bad battery that is shorted, to test that use a voltmeter and test it.
You want to see voltage of 12-12.6 volts. Then while you are watching the voltage, have someone turn the key to start. The voltage should drop down to around 9-10 volts while cranking. No change = poor connections. Drop of the voltage to lower than about 10 volts = bad battery.
Sep 25, 2017 at 9:11 PM
