2004 Chevrolet Impala Battery Drain
RAY MALONE
Chevy, Impala,2004,87000, 4.3L-Car needed a jump i noticed that even when off i could still feel air coming out of the vents and a low humming noise so i went the week disconnecting the batterie cable. then i took out the blower motor fuse to stop the problem until i could go to the shop.after i took the fuse out i did not feel the air so ileft the batterie hookup and in the morning the batterie was dead and now i can,t even jump the car started i need it runing and i don,t have much cash til the end of the month/
Oct 5, 2007 at 9:13 PM
BMRFIXIT
  • 19,053 POSTS
[quote:a36c952c09="Ray malone"]Chevy, Impala,2004,87000, 4.3L-Car needed a jump i noticed that even when off i could still feel air coming out of the vents and a low humming noise so i went the week disconnecting the batterie cable. then i took out the blower motor fuse to stop the problem until i could go to the shop.after i took the fuse out i did not feel the air so ileft the batterie hookup and in the morning the batterie was dead and now i can,t even jump the car started i need it runing and i don,t have much cash til the end of the month/[/quote:a36c952c09]
Did you start the car after you had the battery disconnect
Check the connections @ battery terminals make sure they are tight
As for the fan running check for stuck relay
Good luck
let us know
Oct 5, 2007 at 11:29 PM
Suggested Repair
Confirm the car was started after the battery was reconnected, and make sure both battery terminal connections are tight. For the blower running with the ignition off, check for a stuck blower motor relay.
Conversation Summary
The owner of a 2004 Chevrolet Impala said the car needed a jump and that air and a humming noise continued from the vents with the ignition off. Disconnecting the battery and later removing the blower fuse stopped the airflow, but the battery was dead the next morning and the car would not jump-start. The expert asked whether the car was started after reconnecting the battery, advised checking that the terminals are tight, and suggested checking for a stuck relay.
