Dead battery
2006 CHEVROLET IMPALA
46,000 MILES • 6 CYL • FWD • AUTOMATIC
RESIDENT426
I have a "06 Impala and I have had to replace the battery about a year ago because it would die over night. After that it worked great and no troubles. It has been a year and it is doing it again. So I took it back as the battery was under warrenty and the tech said they would not cover the warrenty. When I asked why they said there was no code for a bad battery. Now is there such a code for a bad battery? I do have mechanical abilites and know that if the battery is dead it resets the computer so a code would not stay for a period of time. And also a bad cell can not be detected by a computer as there are no sensor hooked to it. If there is a code will someone please let me know.
Thank You
Feb 28, 2009 at 8:20 AM
  • 31,937 POSTS
Hi there,
The battery should be load tested and if faulty should be replaced, there is no code for battery faults let's check for a battery darin here is a guide to help.
https://www.2carpros.com/articles/car-battery-dead-overnight
mark (mhpautos)
Jun 18, 2020 at 7:46 AM
KISSAB16
Thank you for this post I had this problem and had to replace the seat switch cost me $84.00 all fixed I love this site.
