Hi, Get A Dvom Meter, Put it On 20 Volt Dc Scale, Put The Red Lead From the Meter To The Positive Side Of the Battery, And the other Lead Of The Meter To the Negative Or Black cable of the battery. Start the car, You should see about 14.2volts or so. With engine running. If that's ok, then you may have a voltage draw in the car. Then we will have to get further into it.
Hope This Helps You,
Good Luck
Edward.S
SPONSORED LINKS
Thursday, June 18th, 2020 AT 2:50 PM
