Check engine light and green flashing key light are on and the car is in limp mode with lights and gauges not working
90,000 MILES • 1.7L • 4 CYL • 2WD • MANUAL
LMOSS84
Hello, my car listed above is a coupe and when I was driving it all of the sudden the temperature gauge and tachometer stopped working in addition to check engine light and green flashing key light come on. The car sounds like it’s in limp mode and sounds like crap while idling. Again this all happened just while driving. I tried replacing spark plugs and coil and replacing the key so far no luck. If anyone could help that would be great thanks!
Reply
Mar 13, 2021 at 11:00 AM
Let's start with getting the codes. Here is a guide that will help with this:
The key indicator is the theft system so if that is on I would not expect the vehicle to start. Is there a history to this? Has the ECM been changed recently?
Also, we need to test the battery and alternator just to make sure we are not dealing with a load shedding issue. That will not cause the vehicle to run poorly but it will cause some of the other issues you are seeing. I suspect we have multiple issues but let's start with codes and go from there.
Let us know what you find with this. Thanks
May 19, 2021 at 6:40 AM
