Car started jumping when put into reverse
95,000 MILES • AUTOMATIC
SYLKI
I took my car to the mechanic because I noticed that the car would give a slight jump sometimes when I put it in reverse. They said my transmission pan needed to be replaced. After they worked on it, I started having more problems with it jumping really hard. I took it back and they said it must be a transmission problem but they do not work on transmissions (which was upsetting because they should have said that before they did any work). Anyways, l also started having problems while I was driving. I would sometimes get a jerk when I would be at about thirty miles. Now it is jerking more consistently and a lot harder. It even does it when I am at twenty miles, which is new. I have been afraid to drive it. I want to know what kind of problem/expensive I may be looking at? Any recommendations for someone in the L.A. area that works on Saturn's? Thanks in advance!
Feb 26, 2018 at 1:55 PM
STEVE W.
  • 15,415 POSTS
It sounds like the transmission is due for a rebuild. A lot of places will change the transmission pans and service the fluids but do not actually work on the transmission itself.
I would find an actual transmission shop and have them test it. It is possible it is a sticking valve or solenoid, but it sounds more like an internal parts failure.
Feb 27, 2018 at 2:42 AM
SYLKI
About how much am I looking at for a repair?
Feb 27, 2018 at 7:31 AM
STEVE W.
  • 15,415 POSTS
That would depend on what the issue is. Could run anywhere from $200.00 up to $2,000.00 depending on what is needed.
Feb 27, 2018 at 10:19 AM
SYLKI
Okay, thanks so much for your help.
Feb 27, 2018 at 11:27 AM
  • 55,732 POSTS
STEVE W. is one of our best!
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Mar 2, 2018 at 3:27 AM
