Car stalls no trouble codes?
150,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TONEDOTTA1983
The car drives fine and just loses RPMs almost stalling. And just can happen any time. Cluster does not flicker so I don't think it's a power issue.
Aug 30, 2023 at 9:52 AM
  • 110,248 POSTS
This could be a couple of things. When it stalls, does it start right back up? I ask because if needs to sit for a bit before restarting, there is a good chance the crankshaft position sensor is failing. Take a look through this link and let me know if anything mirrors what you experience:
Also, a weak fuel pump can respond this way. However, I feel it would be most noticeable when the engine is under a load. Does it seem to happen when climbing a hill or when it is under a load?
Aug 30, 2023 at 2:15 PM
