Car stalling when I turn on the heater fan
2010 KIA FORTE
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
STMBLDR1
when I turn heater fan on, engine will stall. when i turn fan off car will restart.
Oct 30, 2019 at 3:16 AM
  • 110,244 POSTS
Welcome to 2CarPros.
This is an interesting one. When you turn on the fan, is the defroster on or AC? Also, when this happens, are you able to keep the car running by pressing the gas?
I'm trying to determine if it is a grounding issue or the added load from AC/Defroster causing it. If that is the case, it could be a simple idle air control valve.
Oct 30, 2019 at 12:45 PM
