Car stalls after few seconds?
150,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
LUISBURGOS1993
Replaced fuel pump and distributor rotor. Car seemed fine. Car stalls after losing RPMs and almost immediately stall if I try giving gas... Sparks and wires new.
Sep 27, 2022 at 6:42 AM
  • 110,248 POSTS
Have you checked to see if there are stored diagnostic trouble codes? If you haven't, I recommend doing that first.
Here is a quick video showing how it's done:
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scan tool. However, if that is the case, see if a parts store will lend one to you.
Next, a large engine vacuum leak can also cause issues. If you haven't checked for leaks, do that as well.
Here is a link that explains how it's done:
Start with this and let me know the results. Also, let me know if there were codes retrieved and what they are.
Sep 27, 2022 at 1:02 PM
