Car shut off after hitting speed bump
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
TROOKS1981
I was driving and i hit a speed bump which caused my radio to shut off. I continued to drive and i went across the railroad track and it caused my vehicle to shut down. I tried to restart it but it would not. I waited and tried again, it then started but shut back off. It will not start now. If i do get it started it shuts back off.
Apr 26, 2018 at 9:12 AM
KHLOW2008
  • 41,812 POSTS
Such symptoms are usually due to a loose connection somewhere. The bump has loosened some connection to cut off the radio and with it some other power supply. Check all fuses and also grounding points for a start.
Apr 26, 2018 at 11:09 PM
