Car seems to be in limp mode
113,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
DONALD H SCHOENGARTH
Car starts and idles fine, but has a wrench on the screen on the dash. There is no throttle response with the accelerator pedal.
Jul 23, 2017 at 6:43 AM
  • 55,851 POSTS
Yes it is in safe mode. Here is a guide to show you how to get the codes so we can fix the problem:
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 24, 2017 at 8:17 AM
First off there's a wrench illuminated in the middle of the speedometer. The check engine light is off. I got 2 fault codes a p2104 and a p2112
Jul 24, 2017 at 1:10 PM
  • 55,851 POSTS
Those are throttle actuator codes, check the wiring connector by unplugging it. If it seems okay I would replace the throttle actuator.
Here is a guide that will show you what you are in for and a diagram for what its like on your car.
https://www.2carpros.com/articles/how-a-throttle-body-works
and
Cheers, Ken
Jul 25, 2017 at 4:58 AM
I checked both of the connections the both looked good and seemed to connect smoothly. started the car and pressed on the accelerator and the engine idled up about 200 RPM. The engine light came on so I checked the codes a retrieved codes p2104 and p2112. The same codes as the last time.
Thank You
Don
Jul 27, 2017 at 7:23 AM
  • 55,851 POSTS
It sounds like the throttle actuator or throttle position sensor is bad and needs to be replaced. That's where I would head next.
Cheers, Ken
Jul 28, 2017 at 4:06 AM
