Electrical issues
2003 DODGE DURANGO
111,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DRKANUPP
My cars electrical system is going haywire. My windshield wipers will not turn off even though the switch is in the off position. The horn will go off for about two minutes at a time. The doors lock and unlock intermittently. The "brights" light on the dash is illuminated even thought the actual lights are off. The only thing that i can think of is: There was a heavy down pour yesterday and my door leaks and enough water got in to make my seat damp. probably a short somewhere. How do i determine where the short is and how would i fix it? Thanks in advance.
Jul 8, 2017 at 11:48 PM
WRENCHTECH
  • 20,761 POSTS
The BCM (body control module) is located in the left kick panel. I am suspecting it got water inside.
Jul 9, 2017 at 12:23 AM
DRKANUPP
Could i try to dry it out? or does it need to be completely replaced?
Jul 9, 2017 at 12:50 AM
WRENCHTECH
  • 20,761 POSTS
You would have to open it up to determine the extent of the damage. Powering it up while still wet will tend to burn out components internally.
Jul 9, 2017 at 12:52 AM
