When transmission is shifted into gear the engine loses power?
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
RESIDUALSILVER
My car does everything right in park including rev's, when I put her into gear there is no power and will not do anything.
May 22, 2021 at 1:17 PM
  • 110,248 POSTS
When you place it in gear and it does nothing, does the engine rev as if it is in neutral? Also, have you had the can-bus system scanned for trouble codes? CAN stands for controller area network. Basically, all the computers and modules are tied together via a few wires. If you scan the CAN, it will identify problems regardless of what module is it stored in.
Here is a video showing how it is done:
https://youtu.be/InIlnsjOVFA
Let me know what all has been done, if the shifter feels the same, and exactly what it does when placing it in gear.
May 23, 2021 at 1:18 PM
