car revs and struggles to accelerate
146,155 MILES • 1.4L • 4 CYL • FWD • AUTOMATIC
MOPARFUL99
I changed the oil, brakes, and spark plugs on my friends car. After I was finished I cleared the "maint reqd" light off her dash , we put the car in reverse and the engine would build rpm fine but would barely move. Then I put in drive to pull away and the engine built rpms but struggled to gain speed. It gradually improved and does fine in a straight line but turning right it still revs significantly without out gaining speed then it "catches" and accelerates. Feels almost like riding a clutch then dumping it and will accelerate suddenly... Please help im stumped!
Aug 16, 2014 at 7:16 PM
CARADIODOC
  • 34,412 POSTS
Sounds like you drained the transmission fluid by mistake instead of the engine oil. Check the oil level. If I'm right, the oil will be extremely over-full. Trying to force the vehicle to move with a slipping transmission will do serious internal damage very quickly. The clutch plates will overheat just as though you were riding a manual transmission clutch.
Aug 16, 2014 at 7:25 PM
