Turn car off at gas station then it would not start
190,000 MILES • 2WD • AUTOMATIC
TARALEE75
i drove my car for about sixty five miles it ran great no problems, no lights came on. stopped at gas station shut it off came back out and it would not start. no power what so ever, no interior/exterior lights, door ding, windows or locks do not work, nothing at all. no clicking sound when try to start it. tried jump starting it and nothing at all, did not even affect the pickup battery that tried jump starting it. it still will not do anything and has been sitting about five hours.
Feb 14, 2018 at 8:14 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check the battery terminal connections. try real hard to twist both by hand and if either move any at all, tighten it up. then check the ground cable on the engine block the same way. See if voltage (twelve volts) is reaching the fuses in the maxi fuse block that are supposed to be hot all the time from the battery, one of which is the "IGN SW" fuse.
Feb 15, 2018 at 12:05 AM
