Car overheated noticed milky coolant in radiator
2004 BMW 325I
134,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
BELINDAK
Car overheated, towed home, noticed milky coolant in radiator, is it worth repairing?
Jan 22, 2020 at 4:15 AM
  • 110,244 POSTS
Before you can make that determination, you need to determine exactly what happened. Is there any evidence that coolant made its way into the oil? How long was it driven when it overheated? What happens now when you try starting it?
It sounds like a head gasket, but I can't be sure. What I would like you to do is take a look through this link and see if it mirrors what is happening at this point. Once you do that, report back to me and I'll try to help you determine what the most likely cause is. Keep in mind, if the coolant was never serviced, it could be extremely dirty.
Also, please let me know how comfortable you are if I provide directions for replacement of a head gasket.
Take care and I'll watch for your reply.
Jan 22, 2020 at 10:29 AM
BELINDAK
No coolant in oil, after overheating, only driven enough to get out of traffic, after a short wait and cool down car would start again, but called for tow home. Cardboard put under car and noted only small drops of milky greenish spots over several days while the car is sitting. There was no white smoke from tail pipe, nor gush of fluid from underneath. Please advise. Thanks
Jan 24, 2020 at 3:00 PM
  • 110,244 POSTS
Since you are seeing the drops on the cardboard, there may be nothing wrong other than a small leak. If it starts and runs normally, I would make sure the cooling system is full and pressure test it to see if you can determine where the leak is located. It may have just overheated because it was low on coolant. Here is a link that explains how to pressure test the system. You will need a pressure tester, but most parts stores will lend/rent one to you.
https://www.2carpros.com/articles/radiator-pressure-test
On the other hand, if it doesn't seem to run properly now, let me know. At that point, we need to check the head gasket. However, based on what you described, that doesn't seem to be the problem.
I will watch for your reply.
Jan 25, 2020 at 9:12 AM
