car makes grinding sound after clutch instalation
125,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
BUBBLESG4
We changed a clutch car after reassembly the car will not move it kind of tries but then it make a whirring sound. now we did not read all instructions first, so we then after the fact see this note on page it says:to insert a special tool to keep the side gears from coming mis-aliened the axle on drivers side lacks a little over 3/16 of an inch looking into trans axle [pulled passenger side out of trans axle ] it looks like a round rod fell into the axle hole from up inside towards the back.
Nov 18, 2017 at 1:42 PM
JIS001
  • 3,412 POSTS
You will need to replace the unit or take the transmission apart.
When installing a replacement automatic or manual trans-axle assembly into a front-wheel drive vehicle, it is very important to leave the plastic axle-seal plugs in place until it is time to reinsert the axle drive shafts. The axle-seal plugs prevent the differential side gears from becoming dislodged from their proper positions. If the differential side-gears become dislodged, it will not be possible to reinsert the axle drive shafts. If the differential side-gears cannot be returned to their proper positions, it will be necessary to install another replacement transmission assembly, as correction of this condition requires disassembly of the transmission housing.
Nov 19, 2017 at 6:43 AM
