P0171 Fuel Trim B1 System too lean
P1255 Coolant temp sensor short with ground
P0341 XML=>sensor G40 not a plausible signal
P1500 Fuel pump relay (v17) electrical malfunction
P1225 injector 1-N30 short with ground
P1226 injector 2-N31 short with ground
P1227 injector 3-N32 short with ground
P1228 injector 4-N33 short with ground
P1425 evaporate purge valve (N80) short to ground
P1472 evaporate leak detected pump short to ground
P0102 MAF sensor (G70) signal too low
P0135 B151 Heating Circuit Malfunction
P0141 B152 heating circuit malfunction
The mechanic looked throught the car to see if a wire was grounded. He hasn't checked wires under battery. I need to pass emissions in a month. There codes where:
P0102 mass or colume air flow circuit low input
P0171: System too lean ( bank 1)
P0341: Camshaft position sensor circuit range/performance
P1225: manufacturer specific code
P1226: manufacturer specific code
P1227: manufacturer specific code
OBDII Results:
Engine misfire: ready
catalytic converter: not ready
secondary air: unsupported
Heated O2 sensor: ready
Fuel system: ready
Heated catalyst: unsupported
Ac refrigerant: unsupported
EGR flow: unsupported
Comprhensive: ready
Evap control: not ready
O2 sensor: ready
I need help. One person said that off the codes it's a wiring problem the other said its a computer problem. What is it! Can someone help. What do I do?
SPONSORED LINKS
Friday, April 26th, 2013 AT 4:04 PM
