Starter not cranking the engine over?
TOM ROTHSCHILD
  • 2005 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 235,000 MILES
I have a fool battery charge but the engine will not turnover. I get a constant clicking noise when I try to start the car? Alternator?
Monday, January 4th, 2021 AT 11:27 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you might be having an issue with the starter motor.It sounds like the starter motor solenoid is defective or not working.If you remove the starter motor from your car most all auto parts stores will test for free. Here are some tutorials for you to view showing what is involved:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
I would be happy to include do it yourself replacement guides if interested.Hope this helps and let me know if you have any further questions on this issue.Thanks for using 2CarPros.
JAMES1832
  • 6 POSTS
  • 2005 HONDA CIVIC
  • 2.3L
  • 4 CYL
  • 274,000 MILES
I turn the key and her a click but starter does not turn over. I had battery and starter checked and they seem to be ok. If I key turning the key it will finally turn the starter. A friend told me it is probably the ignition switch. Do you have any ideas, before I take to to a mechanic to replace a $450 iGnetion switch?
CARADIODOC
  • 33,874 POSTS
If you're hearing a response when you turn the ignition switch, it's not the switch. If that's a single rather loud clunk each time you turn the switch, there's burned contacts in the starter solenoid or a bad battery cable or connection. Use a test light to measure the voltage on the battery cable at the starter. You'll find 12 volts there. Watch what happens when a helper tries to crank the engine. If the light goes out, there's a bad cable connection. If it stays bright, suspect the starter. When the starter has an intermittent problem like this, any testing has to be done while the problem is occurring.
JAMES1832
  • 6 POSTS
The sound is more like a short beep or squeel.
CARADIODOC
  • 33,874 POSTS
Do the voltage test so we know where we stand. Need to know what is making the sound you're hearing. Could have a bad contact in the neutral safety switch / transmission range switch.
I'll be back in two days to see how you're doing.
JAMES1832
  • 6 POSTS
Thank you!
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,702 POSTS
The starter motor could have a bad spot on it which is typical of the Honda starter. Have you anything to report back on?
GGGGG1987
  • 2005 HONDA CIVIC
  • 2.0L
  • MANUAL
  • 100,000 MILES
I was driving to the shop and I think I heard a whining noise but not sure. Then my radio just cut out, I kept switching it back on, but it would only last a couple of seconds without signal and switch back off again. Then when I went into the shop I left my car running I came out and when I went to reverse back I turned the steering wheel and my EPS light came on my steering locked and my car cut out and now it will not start. I do not know anything about cars so any information would be grateful.
CARADIODOC
  • 33,874 POSTS
"Does not start" can mean different things. I am guessing the starter does not crank the engine fast enough for it to start and run. Based on the progression of symptoms, the typical cause is a failure of the charging system to recharge the battery. You should have seen the "battery" warning light on the dash. The car will be running on just the battery until it runs down, and that will last from a half hour to perhaps as much as an hour. As the voltage in the electrical system slowly drops, various computers will start to shut down, in this case, starting with the radio.
The engine should start with a jump-start, then immediately have the charging system tested. Those tests only take a few minutes. I have been reading way too much lately about the severe damage people do when jump-starting an engine incorrectly, or when they connect battery cables backward. When you connect jumper cables, one connects to the positive post on one car, and the positive post on the other car. The second cable connects to the negative post on both cars.
GGGGG1987
When I jump start it will I have to keep it on the leads to get enough charge to take my car home as it is still at the shop I stay five minutes from there I do not want to be driving it and it cuts out at a dangerous place. Do you think it could be the alternator?
CARADIODOC
  • 33,874 POSTS
A jump-start will get it going right away, but the battery needs to have enough charge to keep the electrical system running for the drive home. Leave the cables on for a good ten minutes or more. The best would be to use a portable charger to charge the battery at a slow rate for an hour or two. To make the battery last as long as possible, turn off the radio, heater fan, and all possible lights. Drive away before the engine has a chance to warm up. That will reduce the likelihood of the electric radiator fan having to turn on.
The generator is the best suspect, but we normally want to rule out wiring problems first.
BUTCHELLA
  • 2005 HONDA CIVIC
  • 4 CYL
  • FWD
  • 80,000 MILES
Car will not start. Lights on dash flicker when turning ignition to start. Put charger on battery same thing. Turned charger to jump start, engine turning over but will not start. Left charger on battery all day on low charge lights on dash flicker while turning ignition. Asked same question earlier. Tried jumping off with another vehicle same thing no turn over. Do take battery to get it tested?
KHLOW2008
  • 41,814 POSTS
Battery not providing sufficient current. Check battery voltage and if possible a high rate discharge test.
Bad main earthing cable. Check and see if the earth cables are ok
Battery terminals bad connection. Clean battery terminals.
Try using jumper from vehicle battery negative to any part of engine to act as additional earthing to see if it works.
