Car door will not close
80,000 MILES • 1.6L • MANUAL
ZOE_DALE
The drivers side of the car door will not close. It bounces back when I try and close it tried to close it slowly and manually do it but still the same.
Help
Oct 13, 2018 at 7:46 PM
MOTOR MASTER
  • 279 POSTS
Hello
My name is Dave. It sounds to me that it is most likely that the door latch is in either the safety or latched position. This is an easy fie, if you take a screwdriver and put it in the latch where the door striker ( the post that stick out of the car that the latch grabs ) goes, pull the door handle and move the screwdriver towards the inside of the door it should open the latch allowing the door to close properly. I hope this has been helpful and thanks for using 2CarPros. Let us know if you need further assistance, we will be glad to help.
Oct 15, 2018 at 5:42 AM
