2007 Vauxhall Zafira boot
2007 VAUXHALL ZAFIRA
VICTORIA68
Electrical problem
2007 Vauxhall Zafira Two Wheel Drive Manual
central locking working but boot will not open
Jan 9, 2010 at 4:11 AM
DAVE H
  • 13,384 POSTS
does it open using the key ?
Jan 9, 2010 at 8:13 PM
ZAFIRA07
my zafira 2007 has same problem but my boot doesn't have key for boot lever only
Jan 9, 2010 at 11:29 PM
VICTORIA68
[quote:172933802d="Dave H"]does it open using the key ?[/quote:172933802d]
Jan 11, 2010 at 3:19 AM
DAVE H
  • 13,384 POSTS
Remove the interior panel from the boot door and manually unlock/open the door (not an easy task with the door closed but it can be done) to discover the actual cause of the fault or get an autoelectrician to check out the doors electric's .. most dealsers will be able to open the door for you ...
Jan 11, 2010 at 10:14 AM
ZAFIRA07
victoria 68 had same problem with mine and it was a fuse took it to local vauxhall garage and they replaced free of charge as under warranty
Jan 12, 2010 at 1:15 AM
