Door Stuck
102,000 MILES • 1.6L • MANUAL
SIAN2HOLTON
My rear drivers side door will not open from either the inside or outside. I have my MOT coming up and need to know how to fix this myself or how much it will cost to get it fixed.
May 29, 2016 at 8:50 PM
  • 110,251 POSTS
The only thing you can do is remove the inner door panel to see if linkage is broken or damaged. The panel is not easy to remove with the door closed, but it can be done. I cannot estimate a cost without knowing what is wrong.
May 30, 2016 at 12:02 PM
