2017 Chevrolet Malibu No Start
1.5L • TURBO • AUTOMATIC
K77R77
I have a 2017 Chevrolet Malibu 1.5L turbo that suddenly died while I was driving. It now cranks or tries to start but will not actually start. The dashboard lights work, but I hear nothing from the fuel pump. I have to press the push-start button again to stop the cranking.
My code reader showed these codes:
- U0073
- U007C
- U007D
I also discovered that the fuel pump fuse location under the hood is completely empty, with no fuse installed.
I need help figuring out why the car died suddenly, whether the missing fuel pump fuse could be the reason it won't start, and what I should test before buying a fuel pump or other expensive parts.
Please give me a step-by-step diagnosis and tell me which fuses, relays, wiring, or electrical connections I should check first.
Oct 9, 2026 at 10:53 AM
  • 55,743 POSTS
Your codes indicate communication network problems:
U0073: Control Module Communication Bus A Off.
U007C: High-Speed Extension CAN Bus 2 Off.
U007D: Low-Speed Extension CAN Bus Off.
But if you mean this fuse in the image below, yes the car must have the fuse to run. I would install a new fuse and see if the engine runs. Let me know.
Oct 12, 2026 at 8:40 AM
K77R77
I did find out my car doesn't have a dedicated fuse for the fuel pump. Instead the ECM does the job (?). Also checked cam shaft sensor front and bac of motor.(I could have these names confused I've never worked on a car.) I've also read about checking a plastic box under the back end of the car, said wires could be corroded or pins bent.
Oct 12, 2026 at 9:59 PM
  • 55,743 POSTS
Yes, that can be the problem, the fuse above is for the fuel pump control module. Can you please upload a video of the engine cranking over so I can tell if the problem is with the engine mechanically? Also, with the key/system on lets check all of the fuses, here is a video and guide to help.
https://2carpros.com/articles/how-to-check-a-car-fuse/
and
https://www.youtube.com/watch?v=G-xNK79Wa-w
Oct 13, 2026 at 6:46 AM
Suggested Repair
Install the missing fuel pump control module fuse and check all fuses with the ignition on. The stored codes indicate communication-bus faults, so confirm power and fuse condition before replacing the fuel pump or other expensive parts. A cranking video was also requested to help rule out a mechanical problem.
Conversation Summary
A 2017 Chevrolet Malibu 1.5L turbo died while driving and now cranks but will not start, with no audible fuel-pump operation. Codes U0073, U007C, and U007D indicate communication-bus problems. The owner found an empty under-hood fuse location and later clarified that the vehicle has no dedicated fuel-pump fuse. The expert identified the relevant fuse as serving the fuel pump control module and advised installing it, checking all fuses, and providing a cranking video before buying parts.
