Car shut off and will not start
2010 CHRYSLER SEBRING
160,000 MILES • 2WD • AUTOMATIC
JAMES ARNONE
Car has been driving fine. I put the car in reverse back out of the driveway and when I put it in drive the car shut off and wont start and it's seems that the gear shifter is stuck but I was able to push the car back into the drive like it was stuck in neutral. Everything lights up when I try start the car but nothing no power steering and can't shift into any gears.
Sep 16, 2019 at 3:13 AM
This could be many things. Unfortunately, we are guessing until we get the codes out of it. If you don't have a code reader then most parts stores can pull them for you. However, if you are willing to invest in a code reader, it will pay for itself over the years if you perform most of your repairs. If you don't do some of your own repairs then it is not a good investment.
Let me know if you can get the codes and we can go from there. If the car does not start then the transmission range sensor could be the issue but is the gear shifter stuck in gear or that moves it just doesn't feel like it changes? Either way, we need the codes to limit this down. Thanks.
Sep 16, 2019 at 4:04 PM
