Car cranks, will not start
115 MILES • 4 CYL • 4WD • AUTOMATIC
JBASNA
  • 6 POSTS
The car was in good running condition, parked in my driveway for about a month. when attempt to start it, the engine cranked slow due to weak battery. after fully charged the battery still couldn't start it. Here are some of what I confirmed:
1.Spark is present at all 4 newly replaced spark plugs.
2.Fuel sprays nicely out of all 4 injectors.
3.Removed the valve cover and checked marks on timing chain,both camshafts marks and crankshaft are correct.
4. compression test on cylinder 1,2,3 and 4 are: 100, 45, 50, 110.
Aug 16, 2020 at 1:23 AM
Good morning,
The compression is you issue.
You have 2 cylinders doing nothing and the other 2 are very low.
https://www.2carpros.com/articles/the-reasons-for-low-compression
You will need to remove the head and have the valves checked and the pistons checked for any damage.
https://www.2carpros.com/articles/symptoms-of-low-compression
Aug 16, 2020 at 1:40 AM
JBASNA
  • 6 POSTS
Thank you for quick reply. I understand the low compression, however, I don't understand an engine going from good running to no start and low compression while parked for a month.
Aug 16, 2020 at 1:58 AM
I understand, but with those readings it will not run anywhere near perfect. You have internal issues.
You can do a leak down test and insert shop air into each cylinder and listen for the leak for the compression.
Aug 16, 2020 at 2:03 AM
