Car cranks, starts but won't idle
95,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
LIETA MOKOENA
Hi
The car has spark, fuel pump works (I know by a slight whistling sound it makes when fuel is available) but won't run. It cranks good, tries to run, then dies. I have seen spark plugs get wet with gas, and they are covered with black material on the electrodes. All show similar signs.
There is also a burning smell when I open a valve cover, which I suspect comes from them plugs. I wondered if there is an oil leak into them as others suggested, but I would rather see if I am missing an electrical issue before I have to head south.
Any help is highly appreciated.
Aug 25, 2016 at 3:53 PM
RENEE L
  • 1,260 POSTS
Lets start with a compression test to see if the engine is okay, here is a guide that will get you started.
let us know what you find
Aug 31, 2016 at 7:55 AM
LIETA MOKOENA
Hi
Yesterday I took out the throttle body, cleaned it with a carb spray, then I increased the idle level this morning. Now it has acceleration issues, and the idle has some skipping, a misfire if I may say.
I had to rest since I took a whole day on it (went as far as taking out the dash)
Thanks for the suggestion, I will look into it if after new spark plugs there's no change.
Sep 4, 2016 at 9:17 AM
  • 55,673 POSTS
It sounds like the engine may have jumped time. But before we check that lets do that compression test to make sure the engine is okay first, you can rent a gauge from the auto parts store.
Sep 5, 2016 at 2:43 AM
