will crank but will not start
174,000 MILES • 3.9L • 4 CYL • 2WD • MANUAL
BANKOTWO
I try to start car, will crank but will not start can we fix it please?
Jan 28, 2020 at 10:10 AM
  • 110,246 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Please run down these guides and report back. Do this and let me know what you find.
Jan 28, 2020 at 11:19 AM
BANKOTWO
Joe, i did as you asked and changed the crankshaft sensor it started right up thank you
Jan 29, 2020 at 3:34 AM
