Check engine light just came on
72,000 MILES • V8 • AWD • AUTOMATIC
NFULFORD
While driving on the highway the car will begin to buck. this usually happens when accelerating but also has happened while just driving. check engine light just came on but quickly went off. took it to garage but no computer codes came up. they told me could be something with transmission but they will have to take it apart to find out??? Very hesitant. What else could it be?
Dec 26, 2013 at 1:27 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent them and try cleaning throttle plate see link....
This guide will help as well
Dec 26, 2013 at 1:59 AM
BMDOUBLE
  • 1,139 POSTS
I have repaired LOTS of vehicles for ignition misfire that were misdiagnosed as trans concerns over the years. Depending on how often it "bucks" it may not set a code right away but at the dealer level a tech can view mode 6 data history and see exactly which cylinder was missing if at all. I would get a second opinion from another shop.
Dec 26, 2013 at 1:39 PM
JASACABEDA
At first I was getting a random tire monitor fault and sensor fault, then when the vehicle goes into drive the dome light wont shut off unless we wiggle the ignition. (And yes the dome switch is off) and now I'm getting check engine light which I got the code at o'reillys P0128 which says coolant low or bad fan or sensor. I had discount tires check the tires with a gadget that shows sensors working. All of these issues started up within a week of each other. So am I dealing with 3 different issues all possible sensors or a main computer unit?
Jan 6, 2020 at 8:32 AM (Merged)
no, the 128 is most likely a bad thermostat.
the tire pressure sensors are another separate unit. it can be checked with a scan tool from a shop to identify the sensor reading wrong. I assume you did check the tire pressures??
the dome light may be a bad switch and needs to be checked.
JASACABEDA
Fast and great response thank you!
Yeah discount tires used a tool and scanned each tire and said they sensors where working. He mentioned the pressure was a little high in each tire. He did ask if I was sure my rig was 2008 since his device was saying it was different.
a difference of 8 lbs and above will trigger the tpms light. i think you need another shop to check it for you.
WEEKSLM
My 2007 Mercury Mountaineer has been running a bit rough while accelerating, around 1500 to 2000 rpms. However, it runs perfectly when I manually turn the overdrive off. This morning, while accelerating on the highway, the engine light started to flash for about 30 seconds. I immediately took my foot off the gas and the light went out. It has not come back on, and I have been careful not to make any fast accelerations or stops. However, I am concerns about what the issue may be and how much it may end up costing me. Ugh!
PROAUTOTECH
  • 288 POSTS
WEEKSLM
Well I was told it was misfiring on the 1st and 2nd cylinder...so they said I would need new sparkplugs first then possibly new coils. Does that sound right?
PROAUTOTECH
  • 288 POSTS
Sounds right, do the plugs, the've probably never been done. Notice the gap difference between them and the new ones.
NIK EWOLDT
We took our 2006 Mercury into the shop when the check engine light come on and it started shaking they told us a mouse had chewed through the wires does this make any sense
DOCFIXIT
  • 18,828 POSTS
Yes it does mice,rats and squirles cause many$$$ in damage each year. Check with auto insurance they generally cover repair
ICPSCIENTIST
Yesterday the car started fine, but died when put into gear. I pulled the battery and had it checked; it came back as "bad".
I got a new battery (higher CCA than previous one) and installed it. Now, the engine either won't start (it cranks but never catches), or it does start but runs very rough and almost right away the dashboard message center tells me the engine is running in "Failsafe" mode.
I am positive that I have good, strong connections at both battery terminals and I've ensured that I have proper engine coolant level (the vehicle owner's manual mentioned this may be a reason for running in "Failsafe").
Any thoughts? Thanks.
Jan 6, 2020 at 8:33 AM (Merged)
DOCHAGERTY
  • 9,606 POSTS
Scanning the car through the OBDII port for currently present faults is going to be my recomendation to you mate. Do that and repost with the outcome please.
VENUS55564
Shakes or Wobbles problem
2004 Mercury Mountaineer 6 cyl All Wheel Drive Automatic
my truck has a shake when turned on and or when accelerating. I checked the plugs and wire. They appear fine. What causes a shake on this truck? Engine light is also on. Does the amount oil in truck cause it to shake?
many thanks,
venus
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
JTELLEZ
2003 Mercury Mountaineer V8 All Wheel Drive Automatic
My suv feels shaky when it's in the drive position and I am stopped at a stop light. When I go 50mph or over it starts to shake even more. The check engine light was blinking on and off but not any more. Can someone tell me what this might be.
SERVICE WRITER
  • 9,123 POSTS
You probably have a misfire. There is fuel that is not being burned and getting into the cat. The cat can ignite the fuel and heat it up to much and break it down.
IF the the light flashes, the chance of damage increases dramatically. You can kill the cat by continueing to drive like this.
You need to get the codes from the computer to begin diagnosing this.
RYCE
What does it mean when my check engine light is blinking and two codes come up. codes p0307 and p0430
HMAC300
  • 48,601 POSTS
307 means number seven cylinder is missing and 430 means the right catalytic converter is clogged or no longer working. The misfire can be anything from a basic problem to injectors, or sensors and best to have a mechanic fix these so you do not waste money on parts that are good.
KERRIART
my 2003 mercury all of a sudden started running very rough and has a sulfer smell and the check engine light came on. I bought a code reader but no codes are being displayed.
  • 75,988 POSTS
1.Defective spark plugs
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Manifold absolute pressure sensor
12.Mass Airflow Sensor
13.Idle air control valve
Note: If it doesn't apply disregard it-
BOBTAILMAN
2003 Mercury Mountaineer 85000 miles
service engine light came on after driving in some snow.no cowboy driving.no other symptoms.curious as to what it could be.
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read., Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the Catalytic converter...misfires...service it right away!
DRE827768
  • 10 POSTS
Truck problems please expert help?
My check engine light is on code said p1299 could someone explain this. Before the check engine light turned on the check gage light would turn on and off every 30minutes lasted about 2 days like this then out of nowhere the check engine turn on and the check gage light was on also and even tho I would accelerate fast the rpm would go to 3 and speed to 10mph it wouldn't go any higher stayed like that for about 2 minutes and it was all shaky also just because i wanted to get home asap the truck didn't turn off but when I got home water was leaking on the bottom don't know exactly where but it was somewhere on the passenger center side. In the last 2 months its been nothing but waisting money I've changed the oil, changed the ac compressor because it was leaking antifreeze also changed the hoses connected to the ac compressor, changed the spark plugs because check engine light said so, and the radiator is about 2 years new
Jan 6, 2020 at 8:34 AM (Merged)
OHYEA
  • 153 POSTS
This code indicates that the engine cylinder head temperature sensor indicates the truck is overheating and going into a fail safe strategy. IBelow is a list and description of the trouble code. You need to first check the coolant level, if it is low then look for a external leak somewhere.you said that is seemed to leak where the thermostat is. In the center behind the alternator. Follow the upper radiator hose. I would pressure test the coolant system to find if you have more leaks than that one location.
Detailed Description
Indicates an engine overheat condition was detected by the cylinder head temperature (CHT) sensor. An FMEM Strategy called Fail-safe Cooling was activated to cool the engine.
Possible causes :-
Engine cooling system concerns.
Low engine coolant level.
Base engine concerns.
DRE827768
  • 10 POSTS
I turned my car on again and drove it couple blocks and it let's me drive it like their is no problem only thing that the check engine light is still on would it still be the sensor you mentioned. What happens if it falls on safety mode?
OHYEA
  • 153 POSTS
Fail Safe Cooling
The vehicle has a strategy built into the powertrain control module (PCM) that will control the engine if it starts to overheat.
Stage 1 of the strategy will commence if the engine starts to overheat. The cylinder head temperature (CHT) sensor transmits a signal to the PCM, which then moves the temperature gauge pointer into the red zone.
If the engine is not switched off and the temperature continues to rise, the Powertrain Check Lamp is illuminated. This indicates to the driver that the engine is approaching critical limits and should be stopped. At this point DTC P1285 is set in the PCM which can be retrieved using a scan tool.
Stage 2 of the strategy will commence if the lamp and temperature gauge are ignored by the driver. The PCM will start to control the engine by cutting out two cylinders and restricting the RPM to below 3,000 RPM. Simultaneously the malfunction indicator lamp (MIL) will be illuminated. This indicates that long term engine damage can occur and vehicle emissions will be affected. At this point DTC P1299 is set in the PCM which can be retrieved using a scan tool.
Air is then drawn into the deactivated cylinders. This helps to control the temperature of the engine internal components. The deactivated cylinders are alternated to allow even cooling of all the cylinders.
NOTE: If the driver is using a high percentage of throttle travel (for example, an overtaking maneuver) when the PCM starts engine deactivation (Stage 2), the deactivation will be delayed for 10 seconds.
NOTE: After 2-cylinder operation has begun, the engine will not revert to 4-cylinder operation, even if the temperature should fall, until the ignition is switched off and then on again.
NOTE: The malfunction indicator lamp can only be extinguished by using a diagnostic tool after the fault has been rectified and the DTC cleared.
Stage 3 of the strategy will commence if the engine temperature still continues to rise. This will result in the engine being totally disabled before major engine damage or seizure occurs. The Powertrain Check Lamp will begin to flash, indicating to the driver that the engine will be switched off after 30 seconds. This allows the driver time to choose a suitable parking place.
OHYEA
  • 153 POSTS
Driving the vehicle even more will cause more expenses. Rent a pressure tester for free at an auto parts place and find leaks to repair. You said it was where the thermostat location is so that might be a culprit as a thermostat stuck in the closed position will prevent coolant flow and cause the temperature to steadily rise. In a matter of minutes, if you fail to notice the problem, your engine will be destroyed
DRE827768
  • 10 POSTS
Oh ok thank you
HMAC300
  • 48,601 POSTS
this can be a couple of things, see pics, one can be the cht sensor and or ect sensor or a short plus what is shown in 1 pic.
ROGERLEE2000
  • 7 POSTS
My check engine light is on and at times I notice a slight "studder" when I am driving and I replaced the EGR valve and no change. The code that reads is as follows:
Exhaust Gas
Recirculation Flow
Insufficient
Detected
SATURNTECH9
  • 30,869 POSTS
Have you checked to see if the egr port is blocked?
ROGERLEE2000
  • 7 POSTS
No I haven't. This was the hardest EGR valve to change :-) how do I check it?
SATURNTECH9
  • 30,869 POSTS
You remove the egr valve start the engine for a few second's if the port's are clear you will hear a loud exhaust leak and the engine will race up.
DRE827768
  • 10 POSTS
My truck shakes when it is to a stop. While I drive no problem its all good but when I stop feels like if someone would be jumping inside. Went to auto zone said its the spark plug #5. How do I know if that's the only problem #5 looks like its leaking something is that another problem?
ROGERLEE2000
  • 7 POSTS
Okay I will do that Sunday after Christmas and see what it does. If that is it where would I go from there? If that isn't the problem what would be the next step? Thank you for your help!
CARADIODOC
  • 34,414 POSTS
You didn't list the mileage so I can't make a judgement based on that, but it could just be past due for a tune-up. The shaking is evidence of a misfire which is most likely what the diagnostic fault was related to. If you know the exact code number that was retrieved, that will indicate which cylinder is misfiring, but you can't automatically assume it is due to the spark plug. Fault codes never say to replace parts or that they're defective. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. Spark plugs and ignition coils are the logical place to start, but other causes must be explored too.
You can't see the spark plugs on your engine so I'm not sure what you're seeing leaking. One test is to switch the ignition coils between cylinder number five and one other one, erase the fault code, then see if the misfire moves to the other cylinder. If it does, suspect the ignition coil.
SATURNTECH9
  • 30,869 POSTS
Let's start with if it is that you would have to clean the port with carbon cleaner and a old speedometer cable on a drill.
HECTOR708
Engine Performance problem
2002 Mercury Mountaineer V8 All Wheel Drive Automatic
My check light is on, i did my tune up and it went off untill 3days later. Engine still vibrates, my trucks use alot more gas and check engine light still on, what can it be
