Van will not start
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
10SFREAK
Van will not engage in gear to start. Battery is completely charged. Every once in a while (maybe happened three to four times in the past couple years) it has hesitated to start but once you 'jiggle' the gear shift it starts and runs fine.
Jan 17, 2018 at 3:00 AM
Good morning.
Tthere is a cable that runs from the transmission selector to the transmission. it needs to be adjusted to a specific point. when it is out of adjustment it will do this issue you currently are experiencing.
have the cable checked to be sure. it may be as simple as an adjustment.
Jan 17, 2018 at 7:40 PM
10SFREAK
Sounds like that is the solution!! Thank you.
Jan 17, 2018 at 7:59 PM
You are welcome.
Jan 17, 2018 at 8:07 PM
